12-19-2007 10:14 AM
The diodes in the module are only to COM. I would never rely on the diodes built into the module anyway. Page 7 of manual for the module http://www.ni.com/pdf/manuals/323355b.pdf calls out for external flyback diodes that are installed at the inductive load.
For a flyback diode to function correctly it must be installed in close physical proximity to the inductive load. Otherwise the inductance of the wire between the diode and the coil causes problems of its own. One of which is inducing electrical noise and hash in adjacent wiring.
12-20-2007 02:33 PM
For more information concerning flyback diodes and your FieldPoint module, check out the following KnowledgeBase articles:
What are Flyback Diodes and Why Are They Used?
Can I Connect a Coil Relay Directly to my FP-DO-400 or FP-DO-401?
