05-20-2009 07:58 PM
I know this is a common error, but I can't seem to find the solution. When I run my program from the Labview development environment, everything works fine.
I build the program and try running it from another work station, and I get the tag name not found error. I have the cFP backplane as a device in my project, but I must not be including something required when I build the executable.
I built another application that seemed to work, but I can't figure out the differences.
Can anyone help?
05-21-2009 04:37 PM
Hi Josh,
Take a look at this KB for troubleshooting steps related to that error message:
http://digital.ni.com/public.nsf/allkb/02EB73D02715981A8625682B00774F8F?OpenDocument
05-21-2009 05:08 PM
Kyle, I read that article before I posted. I am using a Fieldpoint IO point control in the program set to a default value. When I run the program from labview, it finds everything OK.
When I run the compiled program, I use the control to browse to an IO point. It shows it when I browse to it, but can't find it when it tries to read it later.
If I have imported an AIK configuration into my project, how does that information get into the build? It doesn't list it as a separate file. Does it create a default AIK?
05-26-2009 08:52 AM
Hi Josh,
If you run a VI in your FieldPoint project, or deploy the settings to the controller, the IAK settings will be downloaded to the FieldPoint. If you have an executable, make sure you right-click on the controller and select Deploy All to configure the FieldPoint to the Project IAK settings.
07-16-2009 06:15 PM
I have somewhat different problem. Someone has already built an executable file of a fieldpoint application. The fieldpoint configuration IAK file was already imported into the labview project.
My question is, how can I get this configuration file separately?
07-17-2009 06:00 PM
Hi Vills,
The IAK file should have been distributed with the executable. You should be able to find it in the application files, either in the data folder, or some other sub-folder.
