Feedback on the NI Product Documentation Center
I don't like it at all
PDF documents are great, they are easy to read, print and they make logical sense.  This new setup breaks up the data into very segmented sections for no apparent reason.  You end up with little segments that are of little value and rather than scrolling past them, I have to click on them, find the text among all the noise and then can decide it was of no value.  Keep the standard documentation.  The new system adds zero value and a bunch of friction.
(271 Views)
Need to be able to login and download the software I need quickly.
Please allow quick login.
(231 Views)
It looks like PDF docs can be downloaded from the section you're viewing, there's a little download button in the upper right:
Problem is the PDF is being generated from the web content, and the end result looks terrible.
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
(223 Views)
