02-15-2006 07:50 AM
02-15-2006 09:47 AM
02-15-2006 03:49 PM
I don't know why tou posted to this board. You should have replied to your original post.
Anyway, you will eventually have to determine the parity, stop bits, data bits, and flow control of the the instrument. If the manufacturer does not provide this (I can't imagine why they can't do this), experiment in Hyperterminal until you find what works.
How to decode XML is a different question than what you originally asked. When you read the data from the serial port, you'll have to parse it out. LabVIEW contains some XML functions on the Advanced>Data Manipulation>XML palette and there is a shipping example called Read Data From XML File. This uses the Read From XML File function and is designed to read a LabVIEW XML file, you should be able to modify this or use it as a template to extract your XML elements.
