10-13-2014 12:43 PM
I realize there is an official Community Guidelines thread, but I feel it should cover more topics than it does. So here is my attempt to have a thread I can point new users to, if they are unsure how forum etiquette works.
Before Posting a Question
Many posts have been made on the forums over the years and many topics have been covered. You are likely not the first person to attempt something, or having difficulty. Search the forums first for the question you would like to ask. NI's forum search works well but feel free to use Google to search the forums. Try searching with alternate terms, like "System Tray" instead of "Icon Tray".
Posting a Question
When posting a question you should first follow the guidelines linked earlier. In addition to those points I'd like to mention a few more:
When you don't get the help you want
If you posted a question and didn't get any response, or didn't understand the responses you got, do not make a new thread on the same topic. Doing this will fragment the conversation and you will have two groups of people working on the same problem.
Don't simply BUMP a thread with a new post without more information. This is a sign that you don't want to put in any effort and are simply nagging others to help you. If a thread goes dry and you want more help, try getting more information on the subject, or try something and reply to the thread with this new information. This shows you are willing to work towards your goal, and aren't just looking for others to do your work for you.
When you get the help you want
Volunteers put in effort to help you and they want to know they are appreciated. The forums have several ways to say "Thank You" to those that have helped. Here are the preferred methods.
Things Not To Do
Looking For Free Training
Many times new users of NI hardware or software just don't know where to start. They will ask a question but without knowing the terms, or the intended purpose, they will not be able to form a proper question. Here are some free training tools primarily focused on LabVIEW and NI hardware.
6 Hour LabVIEW Introduction
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
More general forum etiquette tips can be found here. Not all of these are relevant to the NI forums but there is very good advice in there. There is also the How To Ask Questions The Smart Way.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
10-13-2014 01:14 PM
Of course if you made a mistake giving kudos or marking a solution, you can easily change that back.
10-13-2014 01:18 PM
@Hooovahh wrote:
- Try giving as much information about the conditions of your question. Things like: What version of LabVIEW are you using? What operating system are you using? What hardware are you using? and What sensors are you using? are a few common ones.
Include code whenever available. Asking somebody to troubleshoot your VI without any code is like asking your mechanic to fix your car without taking your car to him.
10-13-2014 01:43 PM
Okay thought of another one and apparently I waited too long and can't edit my original post.
If you find the solution to your question on your own, posting "I figured it out never mind" does no one else any good. Please explain how you fixed your issue, or how you discovered the answer to your question.
10-13-2014 02:01 PM - edited 10-13-2014 02:02 PM
When attaching code:
If you make claims about speed or benchmarking:
10-13-2014 02:05 PM
I recommend to start a document over in the community. You can update it forever.
10-13-2014 02:23 PM
Great idea. I guess I started a thread because I'm used to other forums where they will have like a forum rules thread that is pinned and updated periodically.
Still I'm enjoying the feedback, and will make a document on the community side later. I want to give others a chance to chime in.
10-13-2014 02:32 PM
Do not mark a post as a solution to your thread until you actually have your problem solved. Many people will skip over "solved" threads. If your problem was not solved, then these people will not be helping.
10-13-2014 11:47 PM
I so wish I could mark that post as a solution right now 😛
10-14-2014 12:46 AM
Be very clear about what you're actually asking. Don't just say things like "it doesn't work". Explain what you're trying to do, what you expect to see and what you actually see. This is crucial because different people think in different ways and something that you think is obvious might not be obvious. Sometimes, just the process of explaining the situation properly could be enough to help you understand it and point you towards the actual problem.
