Feedback on NI Community
Search subscription not working correctly.
Too difficult. I guess I'll just disable it entirely.
___________________
Try to take over the world!
Message 11 of 19
(1,686 Views)
Speaking about search subscriptions, I wonder where I can find some reference about the syntax to use. I would like for example to limit the search to a specific board only, so how do I?
Message 12 of 19
(1,674 Views)
Roberto - unfortunately, it's not possible to setup a search subscription for a specific board. I have raised this enhancement request to Lithium. You may want to explore using a third party tool such as Google Alerts.
As for documentation on syntax, I've asked Lithium to provide this. It seems that certain operators and wildcards work, but I do not have an exhaustive list yet.
Message 13 of 19
(1,656 Views)
The saga continues.
So I cleared my search subscription (and pressed clear and reset, so that it's really empty) and yet I got emails for these two images:
http://forums.ni.com/t5/media/gallerypage/user-id/123634/album-id/358/image-id/189493i633692AFE95DF1...
http://forums.ni.com/t5/media/gallerypage/image-id/189547i60B65E759CFFAD0C
I'm assuming this is because of the "or not" in the name, which matches some kind of rule. I'm not sure why they both have the same name (it only makes sense for the first image), but for that I guess we should blame Jeff, who gave them the names.
___________________
Message 14 of 19
(1,549 Views)
Can you forward me the emails that you received for that notification?
Message 15 of 19
(1,538 Views)
BLAME JEFF! Smiley Surprised  OK, I never expected the search to cover my public album.  Worse, I can't rename the images if they are used in a post, "You [I] have run out of time to edit this message." pops-up.  I deleted those images from my album.  Funny I can delete but not rename.  Lili, that sounds like a Li problem.  What would have happened if I had moved them to a private album?
In my defence, [v!]error.vi was an accurate and descriptive vi name.
"Should be" isn't "Is" -Jay
Message 16 of 19
(1,511 Views)
There is a 30 minute time limit to edit anything such as posts, comments, etc. I wouldn't call it a bug that images (whether public or private) are grouped into that restriction, but I don't think it should be that way. Editing an image title, description, and tags is much different from editing the content within a post. We can raise the enhancement to Lithium about this.
Message 17 of 19
(1,505 Views)
That's OK, Jeff, here's one more data point, and I don't think you can be blamed for that one 😉 :
A message matching your search for "" in community NI Community has been found.
Subject: Ethernet/IP Communication Using NI-Industrial Communications for EtherNet/IP 16.0
Board: LabVIEW
Author: Manuel93
URL: https://lumen.ni.com/idp/niup-cond-unsolicited?providerId=https://forums.ni.com/auth/saml&target=htt...
Sigh.
___________________
Message 18 of 19
(1,493 Views)
Thanks for forwarding these search match notifications. I have sent these to Lithium Support for further investigation.
Message 19 of 19
(1,489 Views)
