09-24-2018 08:51 AM
Over the last few days I've been sporadically getting this error message (with the URL inside changing depending on what I'm doing):
The requested resource
/t5/LabVIEW/measure-time-lapsed-from-reaching-threshold-to-execution/td-p/3839140/page/3
does not allow request data with GET requests, or the amount of data provided in the request exceeds the capacity limit.
Sometimes it persists if I try to reload the page or navigate back and forward again, sometimes it goes away and the page loads properly. Any ideas?
09-24-2018 09:12 AM
Hi arteitle,
We are aware of the issue and our team is investigating it. The workaround for this issue if you should run into it again is to clear your browser cache/cookies.
10-02-2018 08:10 AM
I cleared my ni.com cookies last week and that seemed to have fixed it, then I just went to mark this question solved and got:
/t5/forums/v4/forumtopicpage.markmessageasacceptedsolution/message-uid/3842779
D'oh!
10-02-2018 08:42 AM
Hi arteitle,
Our team has found the root cause and hope to implement it when priority allows. In the meantime, please continue to use the workaround.
11-23-2018 04:14 PM
Have the same problem.
Someone used a wrong string length function? It's unicode.
11-23-2018 10:23 PM
I guess it's not fixed yet ....
11-26-2018 10:30 AM
The core issue causing this issue weeks ago was resolved on our end. If you're still encountering the error, it might be related to a new issue.
We recommend clearing your browser cache. If it happens again, please let us know.
Lili
11-27-2018 09:45 PM
I cleared all NI related browser cache yesterday.
I got 413 Request Entity Too Large again today.
/t5/NI-LabVIEW-CVI-æ•°æ®é‡‡é›†ç‰äº§å“讨论区/请问å„ä½-能å¦åœ¨labview的基础上-用åæ ‡ç³»å®žæ—¶æ˜¾ç¤ºå°è½¦çš„ä½ç½®-拜托å„ä½äº†/td-p/3866252
11-28-2018 09:27 AM
11-28-2018 11:37 PM
Hi Lili, I have the same problem in Japan.
I feel that Japanese DF often causes the problem. On the other hand, I have never seen it in English DF.
Press F5 so many times or back to community top page will resolve but this is inconvenient : <
