Feedback on NI Community
Forum messages view doesn't wrap?
I have a question regarding the page width when viewing posts. Why can't the messages wrap when I resize the browser to a smaller size? If I size the browser window smaller than around 1100px width, I get the annoying scrollbar on the bottom. I have a very large monitor but I like to position 2 browser windows side by side and this feature makes it impossible. Is it the post contents that force this?
Michael Aivaliotis
VI Shots LLC
Message 1 of 16
(7,379 Views)
Michael -
Good question.  You are right that the minimum width in the forums (without scrolling) is somewhere around the 1100 pixel range.  There is the potential that the contents of the messages in a thread can actually increase this minimum - for example, when a wide image is included in the message.  Unfortunately, I don't have access to change the minimum, so we will have to resolve this with larger monitors, higher resolution, or dual monitor setups. Smiley Happy
Have a great day!
Molly K.
Web Support & Operations Manager
Message 2 of 16
(7,366 Views)
Have a great day!
Since this is the only sollution, when can we expect our new hi res. monitor setups to arrive.Smiley Wink
You should have my shipping address, so I'll be watching the shipping dock.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
Message 3 of 16
(7,361 Views)
I use a laptop, so I will need a replacement for the entire computer, plus a 21 inch laptop is hard to carry around, so I will need a Segway too. Smiley Very Happy
Thanks in advance...
Actually, I use 1024x768 and usually I don't need to scroll, but there are times when I do (even if there is no apparent reason for why the display should be wider.
___________________
Try to take over the world!
Message 4 of 16
(7,357 Views)
On my powerbook, the width limit seems to be around 777 pixels, far from the Molly's 1100 limit. Thanks to wrapping, it's still usable at 647 pixels, and that allows having two windows side by side. But, as tst, from time to time I have to maintain a nearly full size to avoid scrolling. There is some hidden bug there...
Message Edité par chilly charly le 08-24-2005 06:48 PM
Chilly Charly    (aka CC)
Message 5 of 16
(7,349 Views)
CC,
Whats happen to your signature, you have nothing below to pressSmiley Very HappySmiley Very Happy
Regards
Ray Farmer
Message 6 of 16
(7,342 Views)
That's Michael fault ! 😉
He told me to suppress the scroll. I did.
Then I spent one hour searching for a command to align the text on the right. No chance.
No way either to put a colored background.:(
There is a strong probability that I'll return to my previous signature, even if it does not work with Fire Fox...:P
Message 7 of 16
(7,337 Views)
Why not use this:
<div align="right">ABC</div>
Michael Aivaliotis
VI Shots LLC
Message 8 of 16
(7,329 Views)
Thanks Michael,
Don't know how I missed that. Could be perfect if you had a solution for the line background...
Message 9 of 16
(7,331 Views)
You have fixed it but strange enough Charly, when you had your faulty sig, the message view actually did wrap...
LabVIEW, C'est LabVIEW
Message 10 of 16
(7,317 Views)
