Feedback on NI Community
Reply
Announcing the NI Idea Exchange!
Re: Announcing the NI Idea Exchange!
Also - please continue to post any language issues you come across.
Laura
Message 41 of 79
(4,380 Views)
I should have taken a screenshot, but earlier today when I was posting a response to a thread, the "E-mail me when someone replies." checkbox text was in French.
-D
DNatt, LV R&D
Message 42 of 79
(4,375 Views)
Laura F. wrote:
You should be able to edit your idea now for 10 minutes after you've posted it without seeing an error.  If you are submitting a new idea I'd love to see confirmation that this is working correctly Smiley Happy
It is still not working correctly. I cannot submit a correction unless I select a second label.
Same problem as shown here. (see also my report to moderator)
Message 43 of 79
(4,370 Views)
Yes, french is still a popular occurrence. Just happened, see image. Sometimes I also still get chinese and japanese and I have to click according to experience. I cannot tell what the links are.
Message Edited by altenbach on 06-06-2009 08:22 AM
Message 44 of 79
(4,353 Views)
Laura F. wrote:
tst- is that language problem persisting for you? Or did you just see it once?
At the time it was (i.e. each time I went into the page). Now I'm not seeing it.
___________________
Try to take over the world!
Message 45 of 79
(4,348 Views)
Hi altenbach -
I was able to confirm this, although I was able to edit a post where I just swapped out one label for another.
Sorry for the inconvenience - please continue to report items that need to be edited to me.
Laura
Message 46 of 79
(4,328 Views)
Ok, once again I think the editing issue is fixed.  Please let me know if you are not able to edit ideas in the 10 minutes after you've posted them because of the "label required" error.
Laura
Message 47 of 79
(4,308 Views)
i'm not sure if it's already said, but i would like a new sort option. Sort by new Ideas or Ideas with new comments.
Mike
Message 48 of 79
(4,286 Views)
One small side effect:
The "Top Kudoed posts" window(?) in the 'main' forums page now needs to be renamed to "Top Kudoed ideas".
Good articles now get buried by good ideas.
Since the idea board has it's own sorting could it be excluded for the "Top Kudoed posts" window?
Message Edited by Henrik Volkers on 06-15-2009 02:05 PM
Greetings from Germany
Henrik
LV since v3.1
Message 49 of 79
(4,243 Views)
Highlighted
This post as an example, some ideas have greater than 10 responses. It took me a while to find the next page, as it did Intaris. The green circled "page navigators" need to be at both the top and bottom of the responses on the pages.
Cheers!
Jack
Wirebird Labs: Expert Toolkits for LabVIEWDeploy, by Wirebird Labs: Expert Toolkits for LabVIEW
Message 50 of 79
(4,213 Views)
