06-05-2009 02:15 PM
Also - please continue to post any language issues you come across.
Laura
06-05-2009 03:54 PM
I should have taken a screenshot, but earlier today when I was posting a response to a thread, the "E-mail me when someone replies." checkbox text was in French.
-D
06-05-2009 07:38 PM
Laura F. wrote:You should be able to edit your idea now for 10 minutes after you've posted it without seeing an error. If you are submitting a new idea I'd love to see confirmation that this is working correctly 🙂
It is still not working correctly. I cannot submit a correction unless I select a second label.
Same problem as shown here. (see also my report to moderator)
06-06-2009 10:21 AM - edited 06-06-2009 10:22 AM
Yes, french is still a popular occurrence. Just happened, see image. Sometimes I also still get chinese and japanese and I have to click according to experience. I cannot tell what the links are.
06-06-2009 01:03 PM
Laura F. wrote:
tst- is that language problem persisting for you? Or did you just see it once?
06-08-2009 09:10 AM
Hi altenbach -
I was able to confirm this, although I was able to edit a post where I just swapped out one label for another.
Sorry for the inconvenience - please continue to report items that need to be edited to me.
Laura
06-09-2009 08:42 AM
Ok, once again I think the editing issue is fixed. Please let me know if you are not able to edit ideas in the 10 minutes after you've posted them because of the "label required" error.
Laura
06-10-2009 10:58 AM
i'm not sure if it's already said, but i would like a new sort option. Sort by new Ideas or Ideas with new comments.
Mike
06-15-2009 07:04 AM - edited 06-15-2009 07:05 AM
One small side effect:
The "Top Kudoed posts" window(?) in the 'main' forums page now needs to be renamed to "Top Kudoed ideas".
Good articles now get buried by good ideas.
Since the idea board has it's own sorting could it be excluded for the "Top Kudoed posts" window?
06-16-2009 10:02 PM
This post as an example, some ideas have greater than 10 responses. It took me a while to find the next page, as it did Intaris. The green circled "page navigators" need to be at both the top and bottom of the responses on the pages.
Cheers!
Jack
