12-03-2010 03:10 PM
I have a NI FBUS PCI card 2 channel, I need to clear the VCR buffer as I am limited to a maximum of 100 VCR per channel, How do I delete all previous VCR's on bot channels. Thank you
12-06-2010 09:37 PM
The VCR information is stored in the MIB block of the device. You can use NI-FBUS C APIs to write zero to the VCR entries to clear the existing VCRs. Here is the procedures and pseudo-code. For more detail information about VCR structure, please refer to Foundation Fieldbus protocol specification.
12-08-2010 08:58 AM
Thank you Vince for the information, however even though your instructions are clear I do not know how to launch NI-FBUS C API. Is this a software package I need to download or is it included on the CD... Appreciate a response...
To further describe my issue is, I am using a NI- FBUS PCI card with tow channels, we use this card to test our production units, each time an instrument is connected to the card a VCR is logged, with the 100 VCR limit, each channel on the NI PCI card only allows me to test 99 units. I need a way for our production techs to clear this VCR buffer or log.
We have two test benches with 2 PCI cards, Bench #1 is dead because 198 instruments have already been configured and the VCR is full, and second bench has channel #1 ful and channel 2 is also about to be full as well, I cannot connect to a new FF instrument when the limit is reached.
Best Regards
Ohmart
12-10-2010 01:04 AM
NI-FBUS C API is a library (nifb.lib) which can be called through your C/C++ program. You need to use Microsoft Visual C development environment to create your application and link these APIs.
For more detail information about how to use NI-FBUS C API, please refer to NI-FBUS Hardware and Software User Manual, Page 4-12, Write Your Application.
The manual is located at Windows Start >> Programs >> National Instruments >> NI-FBUS >> Manuals.
12-10-2010 02:49 PM
Hello Vince,
I tried to use you code but got stuck at the 'memset' function.
I was using VB 6 and looked like this function didn't exist.
Please help!!!!
ohmart
12-12-2010 08:54 PM
The memset function in above pseudo-code just allocates a buffer array in which each element is zero. It is a function in C/C++ standard library. In VB, there is no need to do a memset. When declaring an array, all the elements will be initialized to zero by default.
NI-FBUS has VB API as well. The VB library and examples are located at <NI-FBUS installation directory>\NI-FBUS\MS Visual Basic.
