FOUNDATION Fieldbus
System Management entity is not operational
- NI AT-FBUS Interfacecard
- Windows XP
- NI-Fieldbus 3.1
Installation of the hardware and the software o.k. so far. No Interruptconflict.
I have connect my Fieldbusdevice to my system. When I Expand All with the NI-FBUS Dialog Utility 3.1 I get the following Error:
Error: System Management entity is not operational.
Does anybody has an Idear what does that mean and how I can solve (fix) this problem?
Thank you very much,
Genesiss
(7,250 Views)
Does your system have any existing FF interface module before you connect to AT-FBUS?
If so, there might be some conflicts between AT-FBUS and the interface module.  In that case, please close NI-FBUS Communications Manager, and run the Interface Configuration Uitility, check the settings of your interface port,  specially check the Device Address (Fixed) and Device Type; the suggested values could be "0x1A" and "Basic Device". Then click "OK" and close the Interface Configuration Utility, and try to connect to your system and run NI-FBUS Communications Manager again, see whether it helps.
(7,245 Views)
