I'm trying to read or write block tags/names using nifread or nifwrite commands through the NI driver.
I get back a -2 error, meaning block parameter is not found. I have tried referencing the parameter by name (BLOCK_NAME.BLOCK_TAG), by index (BLOCK_NAME.0.1). I'm programming in a VB environment. Do I not have the right naming convention? Is there a special way the block headers need to be reference.
In NI Communicator or Dialog, block tags are changed by read and write commands built into the user interface.
Thank you
