07-04-2008 03:10 AM
07-04-2008 04:28 AM
Please make sure that this PCMCIA-FBUS adapter works well with your PC first. As I know, there may exists compatibility issues between PCI to PCMCIA adapters and some desktops. You can verify this by the following steps.
1. Check whether the adapter is properly installed. There should be no error in Windows Device Manager.
2. Change the adapter to other PCI slots.
3. Try other PCMCIA devices on this adapter, check whether they work well.
07-04-2008 06:57 AM
07-07-2008 01:34 AM
03-26-2010 01:48 AM
I am having PCMCIA-FBUS Seried 2 card installed in my Dell Latitude/E6400 laptop, which has a Ricoh PCMCIA adapter. i am using ni-fbus configurator 3.2.3. when i start the ni-fbus manager with device connected, i am not able to see the online devices. i am using Moxa U1110 USB to connect the device.
Please let me know how to make this work.
03-30-2010 03:06 AM
Is Moxa U1110 USB a USB to COM adapter? Is the device connected to your laptop through this USB to COM adapter? If so, it does not work because the device is not connected into a FF network.
Could you let me know what device you are using?
