You can run Interface Configuration Utility to check the settings of your PCMCIA-FBUS/2 ports, see whether the board is enabled, the ports have proper fixed address lower than 0x25, and whether the port usage are set to "NI-FBUS".
Otherwise, you might need to contact "fieldbus.support@ni.com" for further support.
