My application consist in a NI USB-8486 convertor connected to a Biffi Fieldbus Valve with integrated PID (FF 2000 v4 ,revision 2). I'm using NI FBUS Configurator software from National Instrumens to create a test project for PID control. For the phisical bus connection i'm using some Phoenix Contact connectors with cables and power supply for the bus. I succeeded to download a simple configuration in Biffi and to force some Open/Close commands through the DO Block but i cann't make any movement using the PID. I tried to use the PID Feedback Control template replaceing the coresponding blocks (follwing the manual instructions) and no succes!! In monitoring all the configured blocks are in the correct Block_Mode, I can see that the pid algorithm is reacting when i change the setpoint from a second AI block(in Manual mode) that i use for this purpose, the Transducer block seems to display correct information - regarding the Setpoint_Read, Position, and the Command_Read:"Enable setpoint"( I'm not sure if this is the correct active command for this parameter) and still ...the movement is not triggered.
I attached also the project, maybe you can give me a hint about this.
Thanks!
