07-19-2005 09:14 AM
07-19-2005 09:11 PM
Hi Bryan, yes, you can use the AT-FBUS card with the lastest version of NI-FBUS Communications Manager (version 3.1.1); and the latest CD of this software is version 3.1, which has slight difference with 3.1.1 version.
However, if you are using some application programs based on NI-FBUS CM 2.3.6 version in your test station, probably you can not run the application programs directly with the latest 3.1 or 3.1.1 version NI-FBUS CM. The reason is that NI-FBUS CM changed its API interface since 3.0 version, you would have to upgrade your application programs by simply rebuilding the application with the NI-FBUS 3.1 or 3.1.1 version library.
11-18-2010 07:20 AM
Is it AT-FBUS (ISA) board suported on nifb 3.x versions anymore?
11-18-2010 07:22 AM
Zry, wrong version on my last post.. Is it supported on 4.x version drivers?
11-18-2010 11:10 AM
NI-FBUS 4.x does not support AT-FBUS anymore.
