04-04-2011 07:25 AM
I had the HSE/H1 connected to my network, but it decided to go crazy on me and drop off the map. I know the IP Address of the unit, but am unable to connect with it anymore. I did a factory reset on the unit, but am unsure if that resets the IP address as well. If that is the case what is the best way to force an IP address on the unit? The status light blinks green at a rather fast rate as well. I can add the ethernet interface board in the interface fonfiguration utility, but can not add the hse/h1 LD since it just sits there and listens for the board forever. I hope it is an easy fix and not a matter of the unit died on me.
Kyle
04-08-2011 03:00 AM
The blinking status LED indicates that the linking device is in standby state. The linking device will be assigned an IP address automatically through DHCP.
Please check whether the linking device and the host PC are in the same subnet. Otherwise, the linking device will not be detected.
