FOUNDATION Fieldbus
Comunicación Foundation Fieldbus
Estoy desarrollando una aplicaión para el diagnóstico de válvulas de control con posicionafores fisher dvc 6200f y 6000f. Cuento con los vi nifbus y la usb 8486. Quisiera saber si existe algun vi de ejemplo qie me guie para programar la comunicación fieldbus de la aplicación y el posicionador, es decir ¿Cómo hago para hacer mover la válvula desde el pc?
Gracias
(5,205 Views)
Hi jdavid7,
Could you please describe your problem in English? And what is your question?
Thanks!
(5,175 Views)
Google translate interprets the message as: "
I am developing an application for the diagnosis of control valves with 6200f and 6000f fisher dvc positioners. I have the vi nifbus and the 8486 usb. I would like to know if there is an example vi that guides me to program the fieldbus communication of the application and the positioner, that is, how do I move the valve from the pc?
Thank you
(5,125 Views)
Hi DavidDyck,
NI provides some example of NI-FBUS communication. You are able to find them in the path: ..\National Instruments\LabVIEW XXX\examples\NI-FBUS\Interface Device after you install the FBUS driver.
(5,110 Views)
I have not been able to control the valve since my application, I explain a little better what I need.
I must make an application that allows me to control the position of a fisher control valve with a dvc6000f positioner with fieldbus H1 communication. The application must allow me to enter a position in% for example (50%) and the valve to be positioned according. I have not found anyone to help me and explain to me what block and what parameter I should enter that position information.
(4,841 Views)
Hi jdavid7,
I am afraid that NI-FBUS VI API doesn't support writing the value in %. Does your device support 0.5 value instead of 50%?
Zheng
(4,824 Views)
Apparently nobody has knowledge of how to send control signals to a dvc6000f positioner using the usb8486. They have not understood my question.
(4,803 Views)
