02-22-2010 03:28 PM
Could any one please explain
all the methods available to store more programs
on NXT bricks?
02-22-2010 04:10 PM
Hi dummi,
There are a couple of things you can do within the NXT Terminal (Tools»NXT Tools»NXT Terminal...):
1. Remove the default programs (like the Try me programs) or the default sounds (.rso files) to save some space.
2. Defrag the NXT by pressing the Defragment button. This will increase the amount of contiguous memory on the NXT and may recover some space.
Kyle S
02-22-2010 05:00 PM
We have tried those two
, is it there
anything else we can do.
02-23-2010 04:25 PM
Hi dummi,
EDIT: I was mistaken, replacing the polymorphic VIs makes no difference in memory.
Are you guys using the same code multiple times in the VI? You can create a SubVI (Highlight code»Edit»Create SubVI) for repeatable code in the VI.
Are you trying to compile a VI and it's too big? Or, are you trying to download extra VIs to the brick?
Message was edited by: Smootastic
02-25-2010 01:18 PM
We are trying to load extra VIs to the brick so that we can have more autonomous options
02-25-2010 01:40 PM
Hi dummi,
Have you used direct mode on the NXT? If you see the NXT Shell application on the brick, go ahead and delete it, it's used for direct mode with the NXT.
Kyle S
02-26-2010 10:22 AM
We have deleted every file that we do not need on the brick. On the average each autonomous VI takes up about 20 to 30 k, is there a way to compress it?
