FIRST Tech Challenge Discussions
LabVIEW 9.0 but where is the toolkit update? is there a toolkit? (Archived)
Update: This discussion applies to Issues from the 2010 FTC season and is no longer relevant for current FTC competition software.
For the 2011-2012 season: Install LabVIEW for LEGO MINDSTORMS and the FTC Toolkit.
My lab view 9.0o does not reconize
my nxt brick no does it  have the "command icons" like motors when you right click.
when i try to install lv86nxt- it unzips and then asks me to install lab view 8.6 and then quits.
I also installed lego mindstroms nxt software but ...
Thanks for the help
Message 1 of 10
(8,739 Views)
Thank you for contacting National Instruments!
If the NXT install is prompting you for LabVIEW 8.6 I believe that you may not have the correct toolkit downloaded to install.  You can download the 2010 software from this link:  LabVIEW for FIRST Tech Challenge Toolkit Download.
Is this the location that you originally downloaded the toolkit or did you get it from somewhere else?  Please try to install the toolkit from this location and let me know if you have any issues during that process.
I hope this helps!  Have a great day!
Thanks!
Bob H
NI FIRST Support
Thanks!
Bob H
Message 2 of 10
(4,965 Views)
Note I was able to doiwnload and unzip the new toolkit.
As you can see in the attached file- I have lab view 9.0 running and the install is suggestion that i need to install lab view 9.0 and nxt module 9.0 before I can install the toolkit.
I was wondering how i get the 9.0 nxt module to work if I installed 9.0
Message 3 of 10
(4,965 Views)
I believe you are getting this error because you have installed LabVIEW 2009 and are trying to install the FTC Toolkit.  However, in order to install the FTC Toolkit you need to install the NXT Module first.  So it is prompting you to install the NXT Module before installing the FTC Toolkit.  Here are the installation instructions from the download page for both MAC and Windows:
Mac Download and Install Instructions
  1. Download the Toolkit for Mac OS below.
  2. Double click lvftc20100f2_mac.zip to extract the compressed folder
  3. Navigate to the NI LabVIEW 2009 LEGO MINDSTORMS NXT Module.dmg within the folder NXT Module 2009 Beta
  4. Doubleclick the disk image to mount it
  5. Open the mounted NI LabVIEW 2009 LEGO MINDSTORMS NXT Module image and doubleclick NI LabVIEW 2009 LEGO MINDSTORMS NXT Module.mpkg to launch the installer
  6. Navigate to the FTC Toolkit 2010.dmg within the folder FTC Toolkit 2010
  7. Double click the disk image to mount it
  8. Open the mounted FTC 2010 image and double-click FTC_2010_Toolkit.mpkg to launch the installer
Windows Download and Install Instructions
  1. Download the Toolkit for Windows by clicking on the link below.
  2. Run the self-extracting installer by choosing Run or saving the file to disk and double-clicking on LVFTC20100f2_Win.exe
  3. Click OK when prompted if you want to proceed with the self extracting archive
  4. Click on the Browse... button to select a location to which to extract the installers. Then click Unzip.
  5. Navigate to the location you specified above and into the NXT Module 2009 folder.
  6. Double-click autorun.exe to begin installing the NXT Module 2009 Beta
  7. Navigate to the location you specified above and into the FTC Toolkit 2010 folder.
  8. Double-click autorun.exe to begin installing the FTC 2010 Toolkit.
Please let me know if you are still seeing the error after following these steps or if you have any questions on the process and I will be happy to assist you.
Thanks!
Bob H
NI FIRST Support
Thanks!
Bob H
Message 4 of 10
(4,965 Views)
i finally realized that you need to do 3 installs
the dvd's
the nxt tools
the nxt tools update
Message 5 of 10
(4,965 Views)
Just as a quick clarification the software you need to install is as follows.
  1. LabVIEW 2009 (ships with the FTC KOP)
  2. LabVIEW NXT Module 2009 (available from the download link Bob provided.  The URL is also on a sticker on the package that contains the FIRST Competition software DVDs)
  3. LabVIEW FTC Toolkit 2010 (available from the download link Bob provided)
The NXT and FTC installers are both contained in a single zip file.  Any patches or updates to the software will be distributed through the same download link.  The current version of the FTC software is 2010.0.0f2.  You can check this in LabVIEW by selecting Help»About FTC Toolkit...
Mark
NI App Software R&D
Message 6 of 10
(4,965 Views)
I'm coaching a new team this year, and I'm running into the exact same problem.  I just installed labview 9 and I downloaded the FTC Toolkit 2010_f3.  I extracted all from the archive and ran the setup program.  The setup program refuses to install because I do not have the NXT module installed.  I referenced the link at the top of this discussion, and the page only has the 2010_f3 update which is what complains about a missing NXT module.   So how does one get that mysterious NXT module support?
Could someone post a specific link to the file?  Thanks!
Message 7 of 10
(4,965 Views)
Never mind, found it finally. All I had to do was post a question first!
https://lumen.ni.com/nicif/us/nilabsnxtmodule/content.xhtml
At least I hope that's the right link.
Message 8 of 10
(4,965 Views)
Just to be clear, the process for the FTC 2010-2011 season is slightly different than the one posted Oct 22, 2009 by BLAQmx. The LabVIEW Education Edition included in this year's FTC kit already includes the NXT Module. So the only add-on you need is the FTC Toolkit (www.ni.com/ftc).
If you are using a commercial version of LabVIEW 2009 or the Student Edition of LabVIEW 2009 (included in last year's FTC kit), you will need to manually install the NXT toolkit first.
Message 9 of 10
(4,965 Views)
I've consolidated installation and activation instructions into the following document: Installing and Upgrading LabVIEW 2009 and the FTC Toolkit
Mark
NI App Software R&D
Message 10 of 10
(4,965 Views)
