02-21-2011 09:12 PM
I'm helping a team and they're getting a really strange error. Robot Main seems to be taking a Very long time to exectue. We put some code in to time how long it takes from loop iteration to loop iteration and the number was coming out in seconds.
We then went to a simple joystick example (From the example finder) and ran that and the lag was in the seconds for the joystick to respond (so we don't think it's the actual code).
There is the possibilty there was some damage to the cRio ethernet port (1) could that be causing the lag?
I pinged the cRio and all times were the < 1ms.
Since we eleminated the Robot main code and used default example code, could the problem be in the hardware? Is there a selftest we can run to check it out? What can be done?
Thank you
02-22-2011 10:47 AM
Have you tried running or building your code or some example code on another computer to see if the problem is specific to the way that one computer is building it?
Also, was this problem always there or did it start suddenly? I would recommend re-imaging the cRIO as well.
Tanya V
02-22-2011 01:06 PM
We re-imaged the cRio to v28 (I beleive was the version). The example program we ran had been build and run on a different computer and different cRio.
I'm pretty sure it's been happening that way all along, since they started trying to use the cRio and the mecanum drive. I'm not familiar with the mecaum drive and that's why we tried a stock example of a joystick, nice, easy, benign.
02-22-2011 02:29 PM
Hello LockheedJoe,
Does the driver station report an error in the diagnostics window referring to the RT loop execution rate? Or, you are simply seeing overall lag in system response? Are any errors reported in the diagnostics window? Does the lag exist when the system in tethered with a e-net cable? Or, during wireless operation?
Sorry for the barrage of questions. I appreciate your follow up, and any additional information you may provide.
Cheers,
Pat C.
Patrick Corcoran
Application Engineering Specialist | Control
02-23-2011 07:13 AM
The driver station was reporting watchdog not fed and something about slow execution in the Robot main (I forget the exact words) in the diagnostics window.
We were tethered during all of our testing (It's the first variable we took out).
I don't mind questions, you're just trying to get to the root of the problem.
