FIRST Robotics Competition Discussions
como pudiera hacer una accion autonoma en el teleop
queremos para mas exactitud que todo los mecanismos de lanzador funcionen en una secuencia con tiempos por ejemplo Banda 2 que funcione 1 seg y se apague atrás después se encienda el lanzador pasan dos y se encienda banda 2 y 1 después de 5 seg  que se apague  todo eso con un solo motor que le piquemos y haga todo eso y tener un botón de pagado de emergencia aparte
este es mi codigo que funciona indivudal del teleop
(4,405 Views)
Hello.  I translated this into English using a web page.  Here was the result.
"we want for more accuracy that all the launcher mechanisms work in a sequence with times for example Band 2 that works 1 sec and goes off back after the launcher goes on two passes and band 2 and 1 turns on after 5 sec that everything goes off that with a single engine that we sting and do all that and have a separate emergency paid button.
This is my code that works individually from the teleop."
If I understand correctly, it sounds like you want to create a generalized set of timing routines:   GET_TIME (Get current time.), START_TIMER (Calculate the end time for a particular delay time.), IS_TIMER_DONE (Check to see if the current time is greater than or equal to the end time.)
Then you can use these in a "state machine" to sequence your actions.
This code could be executed inside Teleop or inside of a loop in Periodic Tasks.
A reference "A Secret book of FRC LabVIEW" may help you.   Sorry, it's in English...
(4,364 Views)
