‎01-13-2012 10:39 AM
The order of the updates should not matter so I don't think that is your issue. I would definitely suggest reformatting the cRIO if you are having trouble imaging it (by putting it into safe mode and then using the imaging tool). You should also make sure that you only have one NIC enabled on any computer you are using to image the cRIO.
‎01-13-2012 10:58 AM
Let me confirm a few details on the reformat. I'm using an old cRIO from last year. I'll set the safe mode switch to safe mode and then power up. When the imaging tool locates the cRIO, I'll format it (and say yes to the safe mode reformat request.) We've had instances where I've tried this and it just sits... No discernable activity. After 20 or 30 minutes, I gave up and canceled. If this re-format is successful, how will I know? How long is it reasonable to wait? If good, I should power off, turn the "safe mode" off and power up. Then run the imaging utility again. ALSO all the other NIC need to be off on the imaging laptop. Does that include wireless?
Does that sound like the right order of steps?
‎01-13-2012 11:46 AM
I've had issues before too. Here are some exact steps that i know have worked for us in the past when things are working well:
Hope this helps.
‎01-13-2012 03:02 PM
On the machine we have here which replicates the issue wolfeman reported originally we are only able to re-image the cRIO when the wireless card is enabled. So if you are having issues imaging the controller I would try it with your NIC's all enabled and with just the one you are using enabled. Which way works for the imaging tool seems highly system dependent. We are still trying to figure out the root cause of the issue but if this fixes the issue for any of you running into it we would definitely like to know about.
So in short if you are having trouble imaging
-Try with just one NIC enabled
-If that doesnt work try enabling Wireless and then other NIC's
‎01-13-2012 09:27 PM
Success!!
We followed the list posted by Lorchess. We disabled the wireless NIC.
Only the connection to the cRIO was enabled.
This is on a HP G62 laptop with an I5 processor and Windows 7.
5 minutes before we kicked everybody out of the shop.... One of the students says "Hey, I think it's working."
It did and it imaged the old 8 slot cRIO.
I'll get a better chance to test it out tomorrow and will post anything else we find.
Thanks for the help!
‎01-13-2012 10:56 PM
I used two different machines an HP dv7t (Win7) and a Lenovo 3000 N100 (XP). I couldn't get either of them to reformat either the FRC-cRIO or the FRC-cRIOII. I could set their IPs, ping them, and access their FTP servers, but reformatting timed out everytime. Routers, disabled/enabled wifi-cards didn't seem to make a difference. Switched to an old Toshiba (XP) and it worked the first time on both of them . . . In the end I had a direct connection and only the wired NIC was enabled.
Kevin, if you want sys_info for any or all of the laptops I can e-mail that to you if you like.
‎01-14-2012 07:27 PM
I saw the same error on a crio II today. My laptop is a Lenovo W520. 16G ram dual quad core and solid state drive. Worked fine reimaging an old crio.
‎01-16-2012 07:00 PM
We have had several more calls on this issue and they have all been resolved by ENABLING the wireless cards in your computer.
If this does not work for you post back or call in.
‎01-17-2012 10:13 AM
We have two of the new cRio IIs. I was able to image one of them with my pc using the router. With the exact same setup, I was unable to image the second one. (Timeout)
I will be bringing in a new PC today to retry the image on the second one.
All things being equal, there may be some variations between different cRio IIs that could be causing the issue.
‎01-17-2012 10:19 AM
Hey mgurgol,
That seems strange that the same setup works differently for two different cRIO's. Are you assigning them different IP addresses? Are both still on the same subnet as the PC?
If you are still having issues imaging one of them I would try direct connected to the PC with all but the NIC in use disabled and then if that doesn't work try with all NIC's (including wireless) enabled
