‎02-03-2016 02:04 AM
Hi, This is Mike from Team 5879. Our team hit an unexpected power down when re-imaging roboRIO, and then it indicates some error occured during firmware update. The error code is 80041CF0. Some infor shown as follows: 1) firmware: 3.0.0f0 2) os: NI linux Real-time ARMV7-A 3.14.40-rt37-ni-3.0.0f2 3)status: Safe mode(Software error) 4)roboRIO image version: FRC_roboRIO_2015_v23 Could anyone help show how to get it fixed? Thanks, MIKE
‎02-03-2016 07:11 PM
Mike_inno,
Is the status light constantly blinking? If so, please call into technical support (866-511-6285) for a recovery file and how to use it.
‎02-04-2016 12:59 PM
Hi. This is Michele from team #6112. We didn't have any kind of power issue but we are getting the same Error code. The status light is fine. We cannot procede at all. I even got to the point where I restored the laptop to factory specs and reloaded all of the software and updates. Still the same program. Help!
‎02-04-2016 02:55 PM
Michele.albright,
What is the status of the LED lights on the roboRIO?
‎02-04-2016 03:04 PM
Hello Michele and Mike,
This error occurs when you are trying to upgrade your Firmware, is that correct? How are you trying to upgrade your firmware, is it through the web interface, through MAX, or another means?
‎02-05-2016 10:01 AM
I'm assuming the web interface. I don't even know what MAX is.
-Michele
The light is on...steady.
On Fri, Feb 5, 2016 at 11:00 AM, Michele Albright <
‎02-05-2016 10:07 AM
Which light is on steady and what color is the light?
When you use the web interface, are you getting this error after you choose "Login" in the upper right corner?
‎02-05-2016 11:54 AM
The big light that is connected to the roboRIO is on steady. I am able to
login but once the firmware starts to update, I get the error code. We are
currently checking the wiring to make sure we don't have a short somewhere.
‎02-05-2016 11:59 AM
By "big light," do you mean the orange colored Robot Safety Light you use at competition to show the robot status?
The LEDs Brian and Rebecca meant are the six LEDs on the upper right section of the roboRIO. They are: POWER, STATUS, RADIO, COMM, MODE, RSL. Knowing the color and behavior of these lights will help us determine what state your roboRIO is currently in to see if this might be leading to the issues we're seeing with the update.
Which version of the firmware are you updating to? How far into the process does it get?
