FIRST Robotics Competition Discussions
Monitor Battery Voltage Level with Driverstation
Is it possible to be able to monitor your battery's voltage level with driverstation?
(7,444 Views)
The driver station should do this by default (in the upper right there should be an indicator showing the current battery voltage).
Kevin Fort
Principal Software Engineer
NI
(4,145 Views)
It's in the upper left. For it to work, you have to follow R64.
(4,145 Views)
Accepted by topic author Team 4376
Also see page 12 of the "Getting Started with the 2012 FRC Control System"
Omar
(4,145 Views)
Also, on the right there is a button that says "Charts". That will show a chart of battery usage, along with lag and a few other things.
"Lockheed" Joe
Testing Blog"
(4,145 Views)
Also, make sure you have a 9201 plugged into Slot 1, and not a 9472.  Careless team members have been known to make that mistake.
(4,145 Views)
