From 11:00 PM CST Friday, Feb 14th - 6:30 PM CST Saturday, Feb 15th, ni.com will undergo system upgrades that may result in temporary service interruption.
02-04-2012 10:49 AM
Is it possible to be able to monitor your battery's voltage level with driverstation?
Solved! Go to Solution.
02-04-2012 01:39 PM
The driver station should do this by default (in the upper right there should be an indicator showing the current battery voltage).
02-05-2012 10:28 AM
It's in the upper left. For it to work, you have to follow R64.
02-06-2012 05:19 PM
Also see page 12 of the "Getting Started with the 2012 FRC Control System"
02-16-2012 06:29 AM
Also, on the right there is a button that says "Charts". That will show a chart of battery usage, along with lag and a few other things.
02-16-2012 11:20 AM
Also, make sure you have a 9201 plugged into Slot 1, and not a 9472. Careless team members have been known to make that mistake.
