02-16-2012 04:52 PM
I have another, for me, when the limit switch is activated, all motors stop. I follow the tutorial in http://www.frcmastery.com/labview-for-frc/2011-frc-steps-to-robot-success/step-4 -add-a-digital-inpu... but i added only déclarations into "Begin.vi" and into "Finish.vi" and nothing in "Teleop.vi". Does anyone have any suggestion ?
Team 3969.
02-16-2012 05:00 PM
From the link you provided I suspect you need this step:
"Modify the Teleop SubVI to replace the momentary joystick button with a limit switch"
What is the desired functionality for your robot? To Stop all motors when the limit switch is activated? In that case you will need to put a case structure in teleop which sets the speed of all your motors to 0 when the limit switch is activated.
02-18-2012 10:30 AM
No, my problem is even I don't add to labview any program the limit switch stop all motors !
I want to stop only one motor (desired) not all.
02-20-2012 09:12 AM
I think in ithat case you will just need to add a case structure which reads the state of the limit switch and sets that desired motor to a speed of 0. If you need help with the motor control pallette take a look at the Basic Motor Control Tutorial on the documents page of this community.
02-21-2012 06:27 PM
We found the problem that was with the wiring, now it works perfectly.
thank you.
