FIRST Robotics Competition Discussions
Lidar Lite using I2C port Setup Help
My team is wanting to use the Lidar Lite v3 sensor this year and I found this on CD for setup.  However, I don't know what the object is that is connecting to the control input (x4) of the Write VI below.  Can someone tell me what it is?
(2,604 Views)
Hi swheeler90,
I believe you're talking about the Build Array function. It can be resized from the top and bottom, and it builds an array of the elements wired to it. You can find it in your functions pallete > Programming (default) > Array > Build Array.
The best of luck at the competition!
(2,590 Views)
I bet that's it, will try tonight. Thx!
(2,581 Views)
