FIRST Robotics Competition Discussions
Reply
Labview (Coding Help) One button inverses/un-inverses controls?
So I don't know if this is what this forum is for, but as one of two coders in my team (+ the main one), I really get pressured by my team to make everything work, and I can't figure something out for the life of me!
So here's what my team wants:
-One button (In our case button 3 [Y]) needs to invert axes X and Y in our drive system when pressed, until pressed again.
I've tried about 10 times so far and every time I either ruin the code and the robot freezes, or we have to hold Y.
I've tried the RS Bistable Flip Flop vi, but maybe I just dont know how to use it???
Thank you all and sorry I can't code xD,
Team 5411
Message 1 of 11
(539 Views)
Accepted by topic author JacksonS.
02-11-2019 03:07 PM
I think this site works really well when I want to figure out some button actions.
Team 358 LabVIEW Programming - http://team358.org/files/programming/ControlSystem2009-/LabVIEW/
I'd looks for "Button Toggle Action (2014)" to get what you want.
JY
AE Specialist, RF and Communications
Message 2 of 11
(530 Views)
I agree with JY,
I would use a Toggle to switch between the two behaviors (as describes here: Use Joystick Button to Toggle Between Cases Using LabVIEW for FRC) and then would make one of the cases switch the inputs (maybe negating them too...).
Message 3 of 11
(525 Views)
I think I might have done something wrong, but I can't see where.
Nothing inverses now. Those values go up to a multiplication on the X and Y axes.
Sorry again for my inexperience!
Team 5411
Message 4 of 11
(519 Views)
02-11-2019 03:05 PM
your false case should look like this.
When the button is not pressed you want to keep the previous value.
Champion CLA Instructor
Making senseless computers do
intelligent real world things
is NOT easy. SO MAKE IT FUN!
Message 5 of 11
(491 Views)
Thanks! This works!
The only thing is that it starts immobile, you have to hit Y to begin the process. We can deal with this though!
Thank you!
Message 6 of 11
(484 Views)
02-11-2019 03:09 PM
Here is a simplified version of what you are trying to do.
and it may fix your issue of starting at zero
Message 7 of 11
(482 Views)
It did, Thank you!
Would give you 5 kudos if I could!
Message 8 of 11
(467 Views)
Highlighted
Hey, we are trying to make this for our motor outputs, and I cannot seem to find the orange node for the program. In which library can we find the node? Thank you!
Message 9 of 11
(356 Views)
Had just found it, never mind.
Message 10 of 11
(355 Views)
