01-29-2015 10:10 AM
We are building an arm on our robot for this year's Recycle Rush competition. We would like to elevate the arm with the little cap-knob on top of the joystick, above and slightly between buttons 3-6. However I have been unable to get these to work. I have been using the dashboard to tell me the status of all joystick axes above Axis 4, or Axis [3] this year. (I am mildly disappointed at how they decided to use arrays this year, and not named clusters like last year.) Last year, I'm sure that the cap was assigned to axes 5 and 6, but I've been unable to use them. I have tried both converting to cluster and unbundling by name, as well as directly indexing the array. My Dashboard Main.vi is attached, I am just reading the joystick values from the already-existing wires. We don't know what the POV does, and we're sure it's not hidden in the buttons array. Can somebody help us get LabVIEW to read the joystick caps?
01-29-2015 12:11 PM
It sounds like you are describing the POV input on the joystick. The control is output from the bottom of the Get Values VI. See the attached VI snippet that you can drag into your TeleOp VI.
The output is in degrees or returns -1 if not pushed in any direction.
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
