01-14-2009 03:25 AM
We've followed this approach:
-- Worked great on PC - running at 38 frames per second (no decimation)
--- But only at 3 to 4 fps
Yow.
Closed dashboard, assuming that the streaming of the real-time images to the driver station / laptop were slowing things down. No dice. Noticed that the front panel for some VIs also show the image and mask. Closed those windows. Still 3-4 fps. Changed decimation from none to 2/2, then 3/3. No discernable difference. (On PC this would already take it to >400 fps!) The world is a lot different at 3-4 fps versus 30 fps.
Thoughts?
Question on the side - when/why does Labview bring display data back to the laptop? I was sort of hoping only when a window was open and asking for them.
Thanks!
01-14-2009 08:14 AM
You should be able to get more than 3 or 4 fps. Most likely, your camera is set to return 640x480 images. It takes ~100ms to decode that size of an image on the cRIO. Assuming the camera takes 30ms to return an image, plus 100 for decoding, and you are now at like 7 fps with no processing or additional overhead. Plus you have lots of pixels to process, 300,000 of them.
The demo sets the camera to 320x240 I thought, and it will be even faster at 160x120. The decode times are ~22ms for 32x and ~8ms for 160. Plus the pixels to process go down by 4x and 16x.
Another thing that will slow down an RT app a huge amount is to add a property node into the loop. This requires a round trip to the host, and will drastically cut performance, even more than an open display.
When/Why data? When a window is open and the data is written to via terminal, local, or property node.
Greg McKaskle
01-14-2009 11:16 AM
Thanks! How about these rash assumptions?
And, lastly, now that the sample code is released on how to do this right (by the experts) - I can chuck all this and start with their code, eh?
That link, by the way is http://joule.ni.com/nidu/cds/view/p/lang/en/id/1215 - Two Color Servo Camera Demo V
01-14-2009 08:33 PM
If the images weren't compressed, it would be much less of a load on the cRIO. In reality, the PPC 603e is a pretty simple architecture, and 400MHz isn't slow, but isn't super fast either.
Greg McKaskle
