Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
FIRST Robotics Competition Documents
Heartbeats in FRC
Heartbeats are a common tool used in embedded systems.  Without having access to User Interfaces (UIs), it's helpful to have a visual indicator that your code is actually running on your robot.  With the cRIO hardware, you could toggle the USER1 LED to create a heartbeat.  How do you perform this same task when the roboRIO doesn't have the USER1 LED?
This snippet shows code that will switch the value on DIO Port 9 every 100ms between True and False.  With a LED connected to DIO 9, with a resistor in series, this would create a flashing LED to act as a heartbeat.  When you start to develop your robot, it's helpful to know your code is running on the robot and this will allow you to know.  The snippet is best placed in the Periodic Tasks.vi found within your Team Code Folder inside your project.heartbeat.png
For information about how to create a circuit for the LED, you can check out this article.
Contributors
