FIRST Robotics Competition Discussions
FRC roboRIO Not Imaging No Matter What
Hello all,
Recently I have been struggling with my FRC roboRIO's imaging sequence, as whenever I attempt to format it, it fails. The message from the Imaging Tool included in FRC Game Tools reads
Unable to download image to target.
Possible solutions:
Possible reason(s):
NI System Configuration: Cannot open file or folder.
Complete call chain:
nisyscfg.lvlib:Format.lvlib:Format 5.3.vi:2890001
RoboRIOImagingTool.lvlib:Reconfig Device.vi
RoboRIOImagingTool.lvlib:ImageManager.vi
RoboRIOImagingTool.lvlib:ImagingToolMain.vi
Status: corrupt firmware, cannot run
I have tried the given solution, and did not want to spend writing them down. I have also tried the NI MAX which failed as well. I have read several other threads, and I still have yet to find one with an error like mine. I am really, really lost and would appreciate any help.
(5,989 Views)
I'm likely going to ask some questions that you've already tried.  I'm not sure what you've read to provide given solutions so I won't know which things you've tried.
What is the status light on the roboRIO doing?
You've tried MAX.  Did you do this in Safe Mode with a Format or did you do something else?
What's the name of the roboRIO in MAX?
Have you tried multiple PCs?
Are you connected via Ethernet or USB?
Is this a fresh roboRIO or are you upgrading an install from past seasons?
(5,940 Views)
Accepted by KryptonCougars
I solved the issue. I apologize for forgetting about this post. Thank you for the response however! I solved it by running the following command and rebooting.
nisystemformat -f -t ubifs && nisystemformat -f -t ubifs -c
Thanks anyway!
(5,936 Views)
