FIRST Robotics Competition Discussions
Error during build of the dashboard project
I got this error while doing the build of the dashboard project.
There were no changes made to the program.
I have never assigned any permissions to my laptop.
I am running Windows Vista
The message said to contact you.
Error 8 occurred at Create Folder in Create Directory Recursive.vi->AB_Dest_LLB.lvclass:Create_Destination.vi->AB_Build.lvclass:Create_Destinations.vi->AB_Application.lvclass:Create_Destinations.vi->AB_Build.lvclass:Build.vi->AB_EXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW:  File permission error. You do not have the correct permissions for the file.
C:\Documents and Settings\Administrator
(5,860 Views)
Look at the build specification and make sure you have access to the default paths. If not, change them to something you do have access to.
(3,097 Views)
Thank you. I modified the path to point to the directory that I wanted the executable stored at and it works fine.
Mike
(3,097 Views)
Please I have the same error message while attempting to compile a LabVIEW FPGA VI, what are the steps to modifying the path? I am new to LabVIEW
(3,097 Views)
