FIRST Robotics Competition Discussions
Double Soleniod Issues
Hello All,
I am having issues getting my double soleniod (SMC Type, 12v) to Run properly off my Soleniod Bumper. We are trying to control the forward and reverse direction using Solenoid output 1 & 2 from 1 button on our joystick. We are having absolutly no luck. I have attach my code.
We programmed it a different way and it seems to operate the solenoid, but i am confused why the attached code wont work.
(4,645 Views)
Hi Jeannie,
This is a interesting one.
The problem is you are using the wrong ENUM to set the Solenoid.
If you Right click on the ENUM constant and select Visible Items>>Digital Display for both Forward and Reverse
you will see Forward and Reverse represents a zero.
Next disconnect the wire from the Solenoid Set and go to the "Value" terminal right click and create constant.
If you show its digital display you will see that the Forward selection has the number 2 associated with it and Reverse has a 3 and Off has a zero.
In order to get the Solenoid Set vi to work properly you have  to use the Solenoid Enum.
The number is the important factor not the name.
So you need a 2 for Forward and a 3 for Reverse but your code was sending a zero for both which is Off to the Solenoid Set vi
you need to remove the bad Enums and replace them with the ones from the Solenoid Set VI.
When the small red dots are gone you know you fixed the problem.
If you still have questions please let me know as I was in a hurry and might have left out some important details.
Mark
(3,522 Views)
Thank you so much! we will give it a shot.
(3,522 Views)
