FIRST Robotics Competition Discussions
Can i use the arcade drive wpi to turn the robot right and left?
I am looking for a way to make th robot turn right and left, can i use the arcade drive wpi to do so..
(4,444 Views)
Hey rorim,
Yes the arcade drive will set the motors to perform a left turn (left motor reverse, right motor forward) if you move the joystick to the left - assuming you have the motors set up in a standard configuration. Are you not seeing that behavior when you use it?
Kevin Fort
Principal Software Engineer
NI
(3,410 Views)
Yep i tested it and it worked.
Thanks!
(3,410 Views)
