OK so I have been working on this project in lab view for several hours now all to know avail. I am trying to write a program so that when the trigger (button 1) is pushed, the robot will activate a spike in a forward or reverse direction. The spikes are wired to the digital side car under PWM 3 which is then connected into slot 4. did I wire the spike wrong? should it be wired into a relay connection? Any help would be necessary.
Blarg! is a most unhelpful thread title. Perhaps a more useful one would be "Trouble getting relays to work" or "Wiring spike relay". Using a bad title means that someone who is an expert on relays wouldn't know that this thread is about relays and might not read it. It's to your advantage to make sure that you have well thought out thread titles.
You have wired the spike relay wrong. It should be wired to the relay output on the digital side car.
