FIRST Robotics Competition Documents
[Archived] FRC 2015 Driver Station Tutorial
This page is archived and no longer updated by National Instruments.
Download PDF Below.
This document describes the new driver station for the 2015 FIRST competition season. Read through it
to learn about new features and functionalities introduced with this software-based driver station.
Contents
FRC Driver Station
Overview
     Main Viewing Areas
Operation Page
     Robot Operation Modes
     Robot Run Information
Diagnostics Page
     Communications
     Version Information
Setup Page
     Configuring Team Number
     Practice Round Parameters
USB Settings Page
Power & CAN Page
Messages & Charts Page
Kevin
Product Support Engineer
Comments
Active Participant sciencewhiz
Active Participant
This seems to use an older Driver Station version that does not allow the choice of language specific dashboards on the setup tab. It should look like this: http://wpilib.screenstepslive.com/s/3120/m/8559/l/92377-frc-driver-station-software/show_image?image...
Member The_Demp
Member
Where does the .ini file for the driver station data storage live now? Can't find where to change the dashboard from the default.
Member yosayoran
Member
I didn't check if it actually works, but the tutorial (tutorial 6 - Creating a Costum Dashboard) sais this: (direct quote) "
Rebuilding the FRC Dashboard Project
After you customize the FRC Dashboard Project, you must rebuild the project so that the Driver Station launches the most recent version of the project.
Complete the following steps to rebuild the project and specify which project the Driver Station launches automatically.
  1. In the Project Explorer window of the Dashboard Project, expand the list of Build Specifications to reveal the FRC_Dashboard application.
  2. Right-click FRC_Dashboard and select Properties from the shortcut menu. If the Application Builder Information dialog box appears, click OK.
  3. Verify that the Target filename is Dashboard.exe. The Driver Station reads this executable file as the file to launch.
  4. Verify that the Destination directory is where you want to save the file. Click Build to build the new project.
  5. Explore to where you saved the new executable file. Copy the new Dashboard.exe file over to the C:\Program Files\FRC Dashboard directory."
Hope this helps you!
Member SierraC
Member
Where can we download just the driver software? I need to update our classmates, and I cant find it.
Active Participant BoKnows
Active Participant
A good starting point to find anything related to FRC is at www.ni.com/frc
There's a link there to the software download page: https://decibel.ni.com/content/docs/DOC-34731
Contributors
