Overview
Some data transmission protocols, such as VITA49, require that each data packet contain only samples from one channel. However, many multi-channel FPGA IP components process data in an interleaved manner. This motivates the development of a component that is capable of receiving interleaved multi-channel data and transmitting packetized data. Due to its high throughput and large capacity, dynamic random access memory (DRAM) is used to solve this problem.
Software Requirements
- LabVIEW 2014 or later
- LabVIEW 2014 FPGA Module or later
- NI FlexRIO 14.0 (or similar) or later
Hardware Requirements
Any NI FPGA target that includes a 512-bit DRAM interface is supported. This includes, but is not limited to the following targets:
- NI PXIe-7972R/7975R/7976R FlexRIO
- NI 7931R/7932R/7935R Controller for FlexRIO
- NI PXIe-5624R IF Digitizer
- NI PXIe-5170R/5171R Reconfigurable Oscilloscope
- NI PXIe-6591R/6592R High Speed Serial Module
Current Version
NI DRAM Packetizer IP 1.0.0»
FPGA Resource Utilization
Slice Registers | 18,000 (3.5%) |
Luts | 18,000 (7.1%) |
BRAMs | 43 (5.4%) |
DSP48E1s | 0 (0.0%) |
