This project instantiates four individual Aurora 8b10b x1 cores on a PXIe-6592R @ 3.2Gbps. The LVFPGA diagram can generate and check patterns. This is intended as a starting point for customers needing to communicate to another Aurora 8b10b device. Each Aurora core is connected to an SFP+ port on the PXIe-6592R, and is capable of transmitting and receiving simultaneously. Please read the readme.docx included in the LabVIEW project before modifying the Aurora configurations in Vivado. The Xilinx .xci file is included in the zip file for the user to see the core settings or modify them:
Latest Version
PXIe_6592_Aurora4x1_ext_v1.zip
Software Requirements
LabVIEW 2015
LabVIEW FPGA 2015
Instrument Design Libraries for High Speed Serial Instruments 15.5
LabVIEW 2015 FPGA Module Xilinx Tools Vivado 2014.4
Hardware Requirements
NI PXIe Controller
NI PXIe Chassis
PXIe-6592R
SFP+ Cable
The attached Code is provided As Is. It has not been tested or validated as a product, for use in a deployed application or system, or for use in hazardous environments. You assume all risks for use of the Code and use of the Code is subject to the Sample Code License Terms which can be found at:http://ni.com/samplecodelicense
