Overview
The example demonstrates the write instance of the digital channels using only one task of DAQmx
Description:
The basic VI would shows how to write a multiple line defined by the user by utilizing the build array function of the LabVIEW
Steps to implement or execute code
To implement this example:
To execute this example:
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 16.0 or compatible
Hardware
cDAQ with C series Digital IO Module
You could have also just used a physical channel constant that reads: "Dev1/port0/line7,Dev1/port1/line0:3" and avoided the build array and DAQmx Flatten Channel to String.
Thanks!!!!!!!!!!
Very useful Thanks
