Example Code
Using the Interpolate 1D Array Function With an Array of Clusters Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows how to use the Interpolate 1D Array Function by building a 1D array of x,y points.
Description
This example shows how to use the Interpolate 1D Array Function by building a 1D array of x,y points. From here, the user can specify what value of x they would like to recieve corresponding y value for. The Interpolate 1D Array function will output the interpolated value.
Requirements
  • LabVIEW 2012(or compatible)
  1. Run the vi.
  2. Input the array
Comments
altenbach
Knight of NI Knight of NI
Knight of NI
on
  • You need to initialize the shift register, else the array will grow without bounds when run repetitively.
  • There is actually no need to use a shift register or display the table with every iteration of the loop. All that needs to be inside the loop is the bundle, autoindexing at the right loop boundary.
  • Instead of the loop, you can also use "index and bundle cluster array" (see here).
