Overview
This VI was created in order to allow a user to use an external timebase in order to measure the period of an external signal.
Description
Use property node to set the timebase source, timebase rate and signal to measure.
Select the counter count incoming signal; select the location of the timebase and set the timebase Rate, as well as other settings”
Requirements
VI Snippet
