Overview
The example is to demonstrate how to update the desired parameters of the counter output while the VI is running
Description:
The operation of the counter output is usually already defined first before it runs, but sometimes, we would like to alter the parameters of the output that we have. With that in mind, this VI would show you how to access the parameters of the counter output while also leveraging the event structure of the VI.
Steps to Implement or Execute Code:
To implement this example:
To execute this example:
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 9.0 or compatible
Hardware
cDAQ with C series Counter Module
Thanks for posting! When you get a chance, could you add a screen shot or two to give folks an idea of what your code looks like? Thanks!
Thanks Doc!!!
