Example Code
Two Analog Output Waveforms With Different Frequencies and/or Different Waveform Types
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This example gives one simple option for generating similar or dissimilar waveforms at the same frequency or different frequencies from each other.
Description
Sometimes it is useful to output two different waveforms at different frequencies. This can either mean two waveforms of the same waveform type at two different frequencies or two dissimilar waveform types at the same frequency.  There is one caveat with this example: it was made with a fixed Sample Clock Rate of 100kHz. The frequency that you input is the desired output frequency of the signal. This means that the desired frequency you input must be an integer divide down of 100,000.
In later versions of LabVIEW and the NI-DAQmx driver, this functionality was included in shipped examples. To find these examples, go to Help » Find Examples » Hardware Input and Output » DAQmx » Analog Output.
Requirements to Run
Software
LabVIEW version 8.2 or compatible
DAQmx 8.3 or compatible
Hardware
NI Multifunction DAQ device with at least two analog output channels compatible with NI-DAQmx
  1. Download the example for the version of LabVIEW you have installed
  2. Configure the following on the front panel:
    • Physical Channel of your DAQ device
    • Maximum and Minimum Value for the amplitude of your signal
    • Signal 1 and 2 types
    • Waveform 1 and 2 Desired Frequency
  3. Run the VI
  4. Observe the Output Waveform on the front panel of the VI
Front Panel
Block Diagram
Comments
Todd S.
NI Employee (retired)
on
Thanks for posting!  Could you please include a screenshot or two of the VI to give us an idea of what the code might look like?  Also, please rename your one attachment to include the LabVIEW version.
Todd S.
LabVIEW Community Manager
John_P1
Trusted Enthusiast
Trusted Enthusiast
on
Anybody interested in doing this might also want to check out the following related example:
Generate Multiple Channels of Analog Output with Different Frequencies
It should be more scalable if you need to use more than 2 channels and has some other benefits described on the page.
John Passiak
Contributors
