Steps to Implement or Execute Code:
Block Diagram Steps:
This file why it can not be used on hardware usb-6009?
Error -200077 occurred at Property Node DAQmx Timing (arg 1) in DAQmx Timing (Sample Clock).vi:4730001->Correlated Finite DO with AI.vi
Possible reason(s):
Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
Property: SampTimingType
Requested Value: Sample Clock
Possible Values: On Demand
Task Name: _unnamedTask<0>
Because the USB-6009 does not have hardware timed DIO, only software timed DIO. Meaning it cannot output digital waveforms as this example is doing.
(Bahasa)
Terimakasih atas jawabnya.
selanjutnya, apa yang harus dilakukan agar program tersebut dapat berjalan
pada USB-6009? apakah tidak bisa?
(English)
Thank you for your answer
*Furthermore, what should be done so that the program can run on USB-6009?
would it not be?*
2016-06-01 23:09 GMT+07:00 crossrulz <web.community@ni.com>:
NI Community <https://decibel.ni.com/content/index.jspa>
Correlated Digital Output with Analog Input Task in DAQmx (Finite) new
comment by crossrulz <https://decibel.ni.com/content/people/crossrulz> View
all comments on this document
<https://decibel.ni.com/content/docs/DOC-10751#comment-49445>
would it not be?*
The USB-6009 simply does not have the capability to run this code.
what can I obtain a compatible file for usb-6009? please help me
I will use an analog as an input and digital as ouput.
2016-06-02 17:06 GMT+07:00 crossrulz <web.community@ni.com>:
<https://decibel.ni.com/content/docs/DOC-10751#comment-49475>
I have a question regarding this example.
I have a slower digital module, for example NI9422 250us response time. I have a faster analog module, for example NI9220 10us sample interval. If I correlate NI9422 to NI9220, I can run the sampling program at the highest 10us interval. Then, what does this mean for digital module? Does its result get interpolated?
