Overview
The example demonstrates how to generate a single pulse or finite pulse train
Description:
This VI is for generating either a single pulse from a counter source or a finite pulse train that repeats. The VI uses a state machine architecture and repeatedly stops and starts the pulse train task. You can set the frequency, duty cycle and time to wait between pulse trains via front panel controls.
Steps to implement or execute code
To implement this example:
To execute this example:
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 16.0 or compatible
Hardware
cDAQ with C series Counter Output Module
Thanks for this vi. I have been trying to simulate a clk signal for an SSI encoder and this does the trick nicely 🙂
No problem Daveadz, I'm glad someone found it useful!
Hi Chris,
I have ‘tweaked’ your original vi to suit what I feel are my needs, but I am experiencing a minor issue.
Occasionally the signal does not appear on the output (PFI28 I’m using).
I have tried putting an 'initialise device' step in prior to using the task but it still does not appear consistently.
Can you advise?
David.
