Example Code
Simple Video Display with Axis Camera
Products and Environment
    Hardware
  • Machine Vision
    Software
  • LabVIEW
    Driver
  • NI Vision Acquistion Software
Code and Documents
Overview
This VI allows a user to take in the images being broadcasted by an Axis camera.
Description
IP Cameras are a type of digital video camera that send and receive data via a computer network. One of the ways to access these cameras is to use a Web Browser and simply type the IP of the camera into the Web Address bar.
This particular VI mimics this procedure by embedding a web browser into the front panel. It uses an Event Structure to capture when the user clicks the Load Browser button and loads the URL into the browser via the IWebBrowser2 Property Node.
  1. Type in the camera's IP address
  2. Run the VI
  3. Click the Load button
Requirements
Software
LabVIEW 8.6 "or compatible"
Vision Acquisition Software 8.6 "or compatible"
Hardware
Axis IP Camera
VI Snippet
Configuring an Axis camera
**This document has been updated to meet the current required format for the NI Code Exchange. For more details visit this discussion thread**
Applications Engineer
Comments
muya
on
The VI worked great.
How would I do image analysis on the web stream I am getting with NI's vision tools.
Rob_Steele
on
Tried downloading and running. The first error, the system could not find the 'TitleChangeCallback.vi'. 2nd error, could not find the 'BeforeNavigate2Callback.vi'. I guess, where would I find these guys?
Rob Steele
muya
on
I think this was posted by students who have graduated by now.
Rob_Steele
on
bummer - if i get something worked out I'll post it
rob
TobyHex
NI Employee (retired)
on
Simple fix. Remove the callback and just have the IP camera load to a webpage. Loaded the new code and it should be working.
Nick
Willhijx
on
The video feeds that I am getting are very large with a "splash" around them. I would really like to be able to trim the splash off and shrink the image. Any ideas?
Justin
Contributors
