When creating a test sequence in TestStand, you may want to ensure that certain report options are set for the sequence, regardless of the current station settings. To accomplish this, you can use the ReportOptions callback in a sequence file to change specific options.
To set the report options for a particular sequence, complete the following steps:
Parameters.ReportOptions.Format = "txt", Parameters.ReportOptions.IncludeLimits = True
TestStand 2014 or compatible
I've been struggling with changing report options on the fly (I didn't want to record all results in a specific subsequence. This example shows quite clearly how to employ the callback on entry to a subsequence but I wish I could find more documentation on the use of specific parameters.
Anyone know how to use the ResultFilterExpression?
